Upgrade From 6.0 to 7.0
Answered Question
Aug 13th, 2009
Are there any licensing issues when upgrading from CUCM 6.0 to 7.0?
When we upgraded from 5.1 to 6.0 we were unable to activate the partition as there was a license issue that had to be resolved.
Thanks Kim
Correct Answer by rob.huffman about 7 years 5 months ago
Hi Kim,
That is correct. The DLU's and Node Licences will be okay but you will need to purchase the Software Feature License for CUCM 7.x
Here is a clip that speaks to this issue;
When you upgrade from an earlier release of Cisco Unified Communications Manager to Release 7.0(2), you must download and install a software feature license to activate the new features.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_2/cucm-rel_notes-702.html#wp616664
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
rob.huffman Thu, 08/13/2009 - 01:48
Hi Kim,
As far as Licensing goes, yes, any upgrade to a new "train" requires the Software Feature License. So for example;
CUCM 6.0(x) to 6.1(x) = No
CUCM 6.(x) to 7.0(x) = Yes
Hope this helps!
Rob
kim_beadle Thu, 08/13/2009 - 02:02
Hi Rob,
thanks for responding.
Our 6.0 license will not cover 7.0 in that case, is this right?
Correct Answer
rob.huffman Thu, 08/13/2009 - 04:25
Hi Kim,
Hope this helps!
Rob
hauchinango Thu, 10/08/2009 - 04:28
So how can this be done safely?
If I roll into a 7.X version on my active partition, and upload the 7.0 license file, will I still be able to revert back to my inactive 6.x partition if needed?
rob.huffman Thu, 10/08/2009 - 04:41
Hi Robert,
Yes, this is one of the great features with the "partition-style" builds :) They give you the flexibility to roll back if necessary. You would need to go through the dB replication steps if a rollback to a lower version is done.
Cheers!
Rob
hauchinango Thu, 10/08/2009 - 07:24
Rob,
Appreciate the response, but to clarify, if I roll back from 7 to 6, will I need to re-upload the 6 license file?
rob.huffman Thu, 10/08/2009 - 08:31
Hi Robert,
No, the Licensing portion would remain intact within the 6.x build :)
Cheers!
Rob
