Cisco Unified Mobility Advantage Compatibility
Aug 13th, 2009
Hi All,
I have ordered CUWL for one of my customer which comes with
CUMA-70-UWL Unified Mobility Advantage 7.0 for CUWL only
How can i know its 7.0(1) or 7.0(2)
The issue is that 7.0(2) is the only version that is supported on the Cisco 7825 Platform as per cisco documentation below,
http://www.cisco.com/en/US/docs/voice_ip_comm/cuma/CUMA_CUMC_Compatibility_Matrix.html
I would like to know if the following hardware is compatible with the Mobility software i ordered or not? If not what is the model of 7825 should i order to be compatible??
I have ordered the following server,
MCS-7825-I3-S31 HW Only MCS-7825-I3 with 2GB RAM and Two 160GB SATA HD
regards
Nouman
htluo Thu, 08/13/2009 - 05:15
When you order from Cisco, it's always the latest version. That latest version if 7.0.2 right now.
Michael
