Split tunnel with a difference
Aug 13th, 2009
I need to configure a VPN3020 to tunnel everthing from RA clients except a specific internet subnet
So I need clients to access all networks except the a.b.c.d/24 network which I need them to access directly from their internet connection.
I have played with the split tunnel options but cannot get this to work.
The only way I can see is to set a tunnel list and list all possible networks except the a.b.c.d/24 network
there must be an easier way?
simplecisco Thu, 08/13/2009 - 04:32
We are now using a cloud based web filtering solution so clients at home need access to this directly from the laptop and also need vpn access to internal networks. I could tunnel only internal networks but that means clients could access everything on the internet. I only want to bypass the tunnel for a single internet routeable range.
simplecisco Thu, 08/13/2009 - 04:57
I did that but when I bring up statistics it says secured routes 0.0.0.0 0.0.0.0
No networks showing in Local Lan?
I am in the right place then.....
simplecisco Thu, 08/13/2009 - 05:38
Which bit? The Client config?
Where do I configure the exception?
I have the networks I do not want to tunnel in the Split Tunneling Network List.
Split Tunneling policy set to Tunnel Everything & allow networks in list to bypass tunnel is ticked.
However when connecing secured routes are 0.0.0.0 not local lan routes?
simplecisco Thu, 08/13/2009 - 10:07
Thanks for the info, I have already tried to configure that and it achieves the result partly.
I specify the internal networks which get tunneled and everything else can go direct out the clients broadband however I want to limit what goes out direct to only a specific subnet.
For some reason the split tunnel policiy is not working.
So the only way I can see of achieving this is to create an Inside network list which consists of every network from 1-197 then every network from 199 - 255
Leaving out the required 197.*.*.* network which I want to route directly
Just need to get clever with the wildcard masks!
I have attached the screenshot again.
What you need to try is:-
1) Create a network list with 197.0.0.0 255.0.0.0
2) Configure on the clientConfig
Enable - Tunnel Everything
Enable - Allow the networks in the list to bypass the tunnel
Choose your network list in the "Split tunnel network list" for the 197.0.0.0
Then ALL traffic should be encrypted - except the 197.x.x.x
simplecisco Fri, 08/14/2009 - 05:51
that is what I originally tried and it didn't work. So I was racking my brains trying something else.
I will revisit it again.
thanks for all your advice
