OSPF: LSA3 - summarisation to what ?
Answered Question
Aug 13th, 2009
Hello
In area0 i have networks 10.0.1.0/24, 10.0.2.0/24 and 10.0.3.0/24 and 10.0.4.0/24. R1 is ABR between area0 and area1. What LSA type 3 will be send into area1 ? (what network and mask will be inside this LSA3?)
Thanx
Correct Answer by ajaykumar2k1 about 7 years 6 months ago
Four type 3 Lsa will be sent.One for each 10.0.1.0/24, 10.0.2.0/24 , 10.0.3.0/24 and 10.0.4.0/24 provided you are not using summarization on ABR.
Networks and mask inside the LSa will be following
1) 10.0.1.0 mask 255.255.255.0
2) 10.0.2.0 mask 255.255.255.0
3) 10.0.3.0 mask 255.255.255.0
4) 10.0.4.0 mask 255.255.255.0
Hope this answer your query
Ajay Kumar
Overall Rating: 5 (1 ratings)
Correct Answer
ajaykumar2k1 Thu, 08/13/2009 - 04:35
Ajay Kumar
Wilson Samuel Thu, 08/13/2009 - 04:41
I believe it would depend upon what you provide under the command "area area-id range address mask" command on the ABR.
However I should be able to cross check that in the lab.
Any other experts?
wilson Samuel
PS: Please rate all helpful posts
