Forwarding Multiple Ports - Cisco 877
Aug 13th, 2009
Hi all, is it possible to specify a range of ports to be NAT'ed on a Cisco 877 router? e.g If you have a VoIP setup and you want to forward 50 RTP ports, can you do this with one IOS commnad?
Thank you.
Paolo Bevilacqua Thu, 08/13/2009 - 04:04
No, you cannot specify a range.
That is rarely necessary, because the router is smart enough to dynamically create NAt translations based on the signaling, SIP or otherwhise.
Paolo Bevilacqua Thu, 08/13/2009 - 15:29
You may be very well right, sorry for saying otherwise.
Still, you shouldn't need any explicit statement like that due to SIP-ALG feature in IOS.
