Unable to detect ASA 5540 via LMS 3.0
Aug 13th, 2009
Even though ASA (single context) is supported by LMS 3.0, I am not able to succeed with device credential checking.
Device: ASA5540, Version 8.0(3)6
The DCR report says 'Device Not Supported'.
Please assist.
Regards.
Joe Clarke Thu, 08/13/2009 - 04:58
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You may need to add more device package support to RME. Go to Common Services > Software Center > Device Update, and download and install all available updates for RME and Common Services. If you are really on LMS 3.0 (i.e. RME 4.1.0), you should first download and install the LMS 3.0.1 update from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 . then install all available device packages. After that, your ASA will be supported.
