SRST transfer question
Aug 13th, 2009
  • Silver, 250 points or more
Below is an extract form our SRST config.
All DN`s are 719xxxx but in realliyu user only dial the last 4 digits
It seems that since I have translations under the fallback, I could not transfer call in SRST unless I entered the DN prefix of 7.... I thought all IP to IP transfer calls are allowed and you only have to hav eteh transfer-pattern commend for IP to non - IP calsl i.e PSTN, Telco- It seems to be due to the Translation rules- Is this normal.
voice translation-rule 1
rule 1 /^7\(...\)/ /7197\1/
voice translation-rule 2
rule 1 /^719\(....\)/ /\1/
voice translation-profile ADD719
translate called 1
voice translation-profile REMOVE719
translate calling 2
application
global
service alternate Default
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm x.x.x.x identifier 1
sccp ccm x.x.x.x. identifier 2
sccp ccm x.x.x.x identifier 3
sccp ccm x.x.x.x identifier 4
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB_xxxx
switchback method graceful
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
limit-dn 7935 1
limit-dn 7940 6
limit-dn 7960 6
timeouts interdigit 4
ip source-address x.x.x.x port 2000
max-ephones 350
max-dn 300 dual-line
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 7...
translation-profile incoming ADD719
translation-profile outgoing REMOVE719
time-format 24
date-format dd-mm-yy
many thanks
