SIP trunk to CallManager Express - No Ring Back
Answered Question
Aug 13th, 2009
Hi there,
I've connected the CallManager Express through a SIP trunk to a SIP provider. I have the following situation:
Sip Telephone Number -> SIP Provider -> SIP TRUNK -> CallManager Express -> IP Phone
When I call the SIP telephone number (either from PSTN or chell phone), then there is no Ring Back.
I hope someone can help me to sort out this issue.
Correct Answer by Paolo Bevilacqua about 7 years 2 months ago
progress_ind setup enable 3
under the incoming voip DP.
Overall Rating: 5 (1 ratings)
Stoyan Stoitsev Thu, 08/13/2009 - 23:29
progress_ind is for h.323 only (at least that's what they say in the command ref) ;)
Dennis Mink Fri, 08/14/2009 - 05:13
once you have produced the debug innformation, after the INVITE from your SIP provider as a result of the incoming call attempt, your gw shoudl send a 180 "RINGING" message back to your SIP provider, see if that is actually happening
