WLSE - AP/WDS fails to complete full authentication phase
Aug 13th, 2009
I need the patch for the following bug. I can't find it anywhere.. Can someone help.. I know people have used it to fix their issues before.
This issue is documented in Cisco bug ID CSCsb47726.
There is a pointed patch available for ACS 3.3.3 (both ACS software and solution engine).
To install the patch on the software ACS, perform these steps:
1.Browse C:\Program Files\CiscoSecure ACS v3.3\Support.
2.Re-name the AironetEAP.dll file to AironetEAP.dll.bak.
3.Copy the new AironetEAP.dll to the same folder.
4.Re-start the ACS services.
To install the patch on the solution engine, perform these steps:
1.Run the autoexec.bat file from inside the patch directory.
2.Log into ACS.
3.Go to System Configuration > Appliance Upgrade Status. Choose the appropriate download.
4.Enter the IP address of the computer from which you run the autoexec.bat
file.
5.After you have uploaded the patch to the ACS, click Install Upgrade.
6.Re-start the ACS services.
Make sure to create an ACS backup before the patch is applied.
aghaznavi Wed, 08/19/2009 - 09:28
  • Silver, 250 points or more
The fix for this bug is a patch that needs to be installed on Cisco Secure ACS. In order to download the patch, open a service request with the Cisco Technical Assistance Center (TAC).
http://supportwiki.cisco.com/ViewWiki/index.php/Wireless_LAN_Services_Module_(WLSM)_access_point_(AP)/Wireless_Domain_Services_(WDS)_fails_to_fully_authenticate_with_Cisco_Secure_ACS_3.3_and_4.0
garrsmith Wed, 08/19/2009 - 09:32
I have got a case opened now. Thanks!
It's a patch 3.3.4 which can only be obtained from Cisco TAC.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
