usasanth1 Thu, 08/13/2009 - 07:51
I already referred that and I'm not able to see any port for two different call manager clusters over the WAN.
Jaime Valencia Thu, 08/13/2009 - 08:40
  • Cisco Employee,
  • Hall of Fame,
    2011
The port IS there, i already looked in the doc.
The port is no different whether you're using it across the WAN/LAN/MAN, etc
Search ICT
The doc contains ALL the ports that CUCM uses for communication between all the different servers and devices.
java
if this helps, please rate
