CSS 11503 SSL termination and 256 bit support
Answered Question
Aug 13th, 2009
Does anyone know if the CSS11503 can support 256 bit SSL termination?
Correct Answer by Gilles Dufour about 7 years 8 months ago
switch/Admin(config-parammap-ssl)# cipher ?
RSA_EXPORT1024_WITH_DES_CBC_SHA Accept RSA_EXPORT1024_WITH_DES_CBC_SHA cipher
RSA_EXPORT1024_WITH_RC4_56_MD5 Accept RSA_EXPORT1024_WITH_RC4_56_MD5 cipher
RSA_EXPORT1024_WITH_RC4_56_SHA Accept RSA_EXPORT1024_WITH_RC4_56_SHA cipher
RSA_EXPORT_WITH_DES40_CBC_SHA Accept RSA_EXPORT_WITH_DES40_CBC_SHA cipher
RSA_EXPORT_WITH_RC4_40_MD5 Accept RSA_EXPORT_WITH_RC4_40_MD5 cipher
RSA_WITH_3DES_EDE_CBC_SHA Accept RSA_WITH_3DES_EDE_CBC_SHA cipher
RSA_WITH_AES_128_CBC_SHA Accept RSA_WITH_AES_128_CBC_SHA cipher
RSA_WITH_AES_256_CBC_SHA Accept RSA_WITH_AES_256_CBC_SHA cipher
RSA_WITH_DES_CBC_SHA Accept RSA_WITH_DES_CBC_SHA cipher
RSA_WITH_RC4_128_MD5 Accept RSA_WITH_RC4_128_MD5 cipher
RSA_WITH_RC4_128_SHA Accept RSA_WITH_RC4_128_SHA cipher
The following 256 bits cipher is already supported :
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Fri, 08/14/2009 - 00:12
  • Cisco Employee,
We only support the following ciphers and there is no more development on the CSS.
So don't expect new ones to be added.
CSS11503-2(config-ssl-proxy-list[gdufour])# ssl-server 1 cipher ?
all-cipher-suites
dhe-dss-export1024-with-rc4-56-sha
rsa-export1024-with-rc4-56-sha
dhe-dss-export1024-with-des-cbc-sha
rsa-export1024-with-des-cbc-sha
dh-anon-export-with-des40-cbc-sha
dh-anon-export-with-rc4-40-md5
dhe-rsa-export-with-des40-cbc-sha
dhe-dss-export-with-des40-cbc-sha
rsa-export-with-rc4-40-md5
dhe-dss-with-rc4-128-sha
dh-anon-with-3des-ede-cbc-sha
dh-anon-with-des-cbc-sha
dh-anon-with-rc4-128-md5
dhe-rsa-with-3des-ede-cbc-sha
dhe-rsa-with-des-cbc-sha
dhe-dss-with-3des-ede-cbc-sha
dhe-dss-with-des-cbc-sha
rsa-with-rc4-128-sha
rsa-with-rc4-128-md5
russ Fri, 08/14/2009 - 00:50
Many thanks for the reply Gilles.
Is 256 bit supported on ACE, or will it be on the roadmap?
Correct Answer
Gilles Dufour Fri, 08/14/2009 - 00:56
  • Cisco Employee,
Gilles.
russ Fri, 08/14/2009 - 00:59
Excellent news.
Thanks for the prompt response.
