call not going thru
Aug 13th, 2009
i hav 2811 router with hwic-adsl and vic2-fxo. the vpn and internet is working fine everything is pinging n all but whenever i call there is no tone and incoming calls are coming thru but thn no audio. i think this is a routing prob. please help me urgent thanku
voice-card 0
crypto pki trustpoint TP-self-signed-2459928928
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2459928928
revocation-check none
rsakeypair TP-self-signed-2459928928
crypto pki certificate chain TP-self-signed-2459928928
certificate self-signed 01
3082023E 308201A7 A0030201 02020101
quit
username xxxxx privilege 15 secret 5 xxxxx
archive
log config
hidekeys
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxx address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA2
match address 103
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface FastEthernet0/0
no ip address
duplex full
speed auto
no mop enabled
interface FastEthernet0/0.1
description $ETH-LAN$
encapsulation dot1Q 1 native
ip address 10.2.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 0/50
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxx
ppp chap password 0 xxxxx
ppp pap sent-username xxxxx password 0 xxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http secure-server
ip nat inside source list 2 interface Dialer0 overload
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=FastEthernet0/0.1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.2.1.0 0.0.0.255
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.2.1.0 0.0.0.255 10.2.2.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address 101
control-plane
voice-port 0/1/0
cptone AE
connection plar opx 2101
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 1 pots
destination-pattern 8T
port 0/1/0
dial-peer voice 6 voip
destination-pattern 22..
session protocol sipv2
session target ipv4:10.2.2.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 7 voip
destination-pattern 9T
codec g711ulaw
no vad
telephony-service
em logout 0:0 0:0 0:0
max-ephones 35
max-dn 35
ip source-address 10.2.1.1 port 2000
auto assign 1 to 35
system message Chapal
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 8
create cnf-files version-stamp 7960 Aug 11 2009 12:23:17
ephone-dn 1 dual-line
number 2101
mustafa_chapal Thu, 08/13/2009 - 09:32
the calls to other extensions under this cme are fine but the outgoing calls over vpn to other cme fail and incoming calls that come over vpn have no audio.
Paolo Bevilacqua Thu, 08/13/2009 - 09:38
VPN is not set correctly, and/or some kind of firewall/ACL is blocking audio and outgoing calls.
mustafa_chapal Thu, 08/13/2009 - 09:46
so how should i solve it. i think that if there is any way of removing source in the ping and directly ping to 10.2.2.0 network from 10.2.1.1 interface on the router
Paolo Bevilacqua Thu, 08/13/2009 - 09:48
What are you talking about ?
Your VPN must be transparent, each phone and CME must be able to ping the other side.
Just to be clear, is this a lab and you're a student ?
mustafa_chapal Thu, 08/13/2009 - 09:49
firewall is disabled but as the cme and vpn are on the same router; the router is unable to forward it directly to the 10.2.2.0 network. before it was fine when i had cisco 877 router for adsl and vpn while 2811 router for cme only so before 2811 forwarded the calls to the interface of cisco 877 which then forwarded further to the other site over vpn
