Any way other than CM to install code on 7941 Phone?
Aug 13th, 2009
Is there any other way besides access to a call manager to install code on a 7941 IP phone after a factory reset? (Tech support had me do this - I KNEW I shouldn't have done this) :(
I am in a remote location and can't reach the call manager even though my ASA shows it is responding in the logs. It just sits there and says "Registering"
Overall Rating: 4 (2 ratings)
Jonathan Schulenberg Thu, 08/13/2009 - 13:06
  • Cisco Designated VIP,
    2017 IP Telephony
Yes but it is a lot of work. You essentially have to create a TFTP server, properly configure the XML files the phone looks for and unzip the correct version of firmware from CCO. It's usually not worth it for a single phone.
Also, if the phone is getting to a "registering" state, it sounds to me like it already got its firmware but the SIP/SCCP signaling is not working.
dannymget Mon, 08/24/2009 - 00:28
...or use a distribution called "Trixbox" on an older PC, just activate Cisco Phone support on the console. That includes the TFTP and the folder structure. Also, basic phone files are already there. Just add the firmeware files and edit the XML file. Point the DHCP option to the Trixbox and it's done.
Danny
