l2tpv3 pass through gre/ipsec
Aug 13th, 2009
i have already l2tpv3 tunnel between 2 routers :
l2tp-class l2tpv3.class
authentication
digest secret 7 0701234D4A2A363732010E0F162F3F hash SHA1
password 7 082F4E4F0D3A2A25370A1910223B253B20222D0103
receive-window 100
retransmit retries 10
pseudowire-class cisco-class
encapsulation l2tpv3
interworking ip
protocol l2tpv3 l2tpv3.class
ip local interface Loopback0
ip pmtu
interface Loopback0
ip address 192.168.254.252 255.255.255.255
interface FastEthernet0/2.70
encapsulation dot1Q 70
xconnect 192.168.254.244 1020 pw-class cisco-class
my question is that i am going to setup GRE/IPSEC between the 2 routers , but the 2 loopback interfaces of the lt2pv3 tunnel will be routable through the GRE/IPsec tunnel , is this optimum solution & will it work , or there is a nother solution to secure the l2tp " l2tp/ipsec)
bwilmoth Wed, 08/19/2009 - 09:32
  • Silver, 250 points or more
There will not be any issue in configuring the loopback interfaces with GRE/IPSEC configuration. You can use the physical interface (or the loopback interface) IP addresses to identify Internet Key Exchange (IKE) peers.
The below URL illustrates an IP Security (IPSec) configuration using a generic routing encapsulation (GRE) tunnel between two routers. IPSec can be used to encrypt GRE tunnels to provide network layer security for non-IP traffic, such as Novell Internetwork Packet Exchange (IPX), AppleTalk, and so forth. The GRE tunnel in this example is purely used for transporting non-IP traffic. Hence, the tunnel does not have any IP address configured. Here are some configuration considerations:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a0080093f70.shtml
