No Audio - IPC users on same LAN
Aug 13th, 2009
This is really crazy - All users are using IPC - each user can talk with other users in different LAN segments, but users within the same LAN segment can not always hear each other.
All users are using IPC on an XP laptop connected to a Cisco AP - 1131. Somtimes I can reset the wireless adapter and it will start to work, other times this has no effect. No Firewalls are configured on the Wireless Adapters of the Dell Laptops.
I am at a loss - any ideas?
CUCMBE Version 7.0
IPC Version 2.1.2
Heath
paolo bevilacqua Thu, 08/13/2009 - 13:00
  • Hall of Fame,
    Founding Member
When this happens, can you ping between involved PC's ?
paolo bevilacqua Thu, 08/13/2009 - 13:30
  • Hall of Fame,
    Founding Member
Press ? twice on the IPC, will tell you if packets are lost.
Just another way to isolate further.
KonradStepniewski Thu, 08/13/2009 - 13:02
  • Silver, 250 points or more
Have you tried to isolate problem? I mean check RX and TX when CIPC call is made, next you can wireshark packets, then check settings on switch, etc...
