transfer to a extension during the greetings in call handlers
Aug 13th, 2009
I already configured the call handler and everything its ok, but I want that the caller can dial a extension during the greeting and transfer to that extension like 101, not using caller input 0-9, I check the combobox “Allow Transfers to Numbers Not Associated with Users or Call Handlers” in greeting, but when the caller dial the extension during the greeting , hear “you cannot be transfer to this number, check the number and try again”, also I created a restriction table to allow transfer, but I don't know what else to do, pls help.
Hoan Mai Thu, 08/13/2009 - 14:29
In CM, make sure that the VM ports calling search space can reach the phone you're transferring to.
andresfmg Thu, 08/13/2009 - 14:38
the unity can reach the extension, the css is not the problem, any idea ??
andresfmg Thu, 08/13/2009 - 14:46
i resolved the problem, was "Default System Transfer" in the "Restriction Tables", the * was enable block.
