ATM Map Problems
Aug 13th, 2009
I am having trouble connecting to a few ATM elements on the network. When I do a "show atm map" I noticed that the entry for the devices that I cannot connect to do not have a VPI/VCI entry. (Please see attached file). I do not know why this is happening since they should be created automatically. Any help would be greatly appreciated. I have also attached the configuration for the ATM interface facing those devices.
Paolo Bevilacqua Thu, 08/13/2009 - 15:02
Is this a network of routers ?
Do you necessarily have to use SVC ?
Using PVCs would simplify configuration, eliminate all issues with call setup and tear-down, eliminate all and any issue with mapping, eliminate broadcast traffic.
In summary all very good things.
timluttman Thu, 08/13/2009 - 16:28
Thanks for the quick response. The network is an ATM ring of Marconi switches connected to a 7204. I don't need to use SVC's. I am mostly curious as to why after working with no problem in this configuration for years suddenly stops. And it is only two switches that I cannot connect to. Looking at the arp cache on the two switches I see that the NSAP entry for the router is correct.
Paolo Bevilacqua Thu, 08/13/2009 - 16:47
Probably you meant for "many years" :)
Some data structure may have got corrupted, if you could pinpoint to a single device (ARP server? not sure), rebooting it could fix everything.
Again, if you have a chance to switch to PVCs, be reassured this network will enjoy absolute stability for the rest of its life.
