Access-list on Dialer Interface
Aug 13th, 2009
Hi All,
How/where do I configure an access-list to secure an ADSL interface that is configured for dynamic IP? Basically I just wanted to add only one or two lines to the ACL e.g.
access-list 102 permit tcp any host (dialer0 interface) established
access-list 102 deny ip any any log
inter dialer0
ip access-gr 102 in
If this can't be done then how does one secure a dialer interface that is configure for dynamic IP?
tks,
Donavan
ivarnhagen Thu, 08/13/2009 - 20:30
that should work, but it isn't the most secure solution. You might want to check out the Cisco IOS integrated firewall:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/
http://www.cisco.com/en/US/docs/routers/access/500/520/software/configuration/guide/520scg_security.html
(Commands might be different for your device...search for the software configuration guide for your model)
hth
