Jaime Valencia Thu, 08/13/2009 - 16:36
  • Cisco Employee,
  • Hall of Fame,
    2011
Simply because the system does not allow more than 5 OUs. The system is working as designed.
As workarounds either modify the AD structure, use parent OUs or make sure the user you used to integrate only has read rights over the OUs you want to sync.
This has been asked several times before, PLEASE search NetPro for answers.
java
if this helps, please rate
benzhao98 Thu, 08/13/2009 - 16:45
thank you very much.
I am sorry. I have searched but did not find any useful result.
I have test that did not designate the ou in ldap directory, but got all users in AD,about 20 thousand.
benzhao98 Thu, 08/13/2009 - 17:37
I am not sure that can CCM5.1.2 support over 200000 end user by ldap?
Jonathan Schulenberg Fri, 08/14/2009 - 18:22
  • Cisco Designated VIP,
    2017 IP Telephony
