SRST First Time
Aug 13th, 2009
Hello All,
I have configured a SRST on a 2801 router using MGCP in normal mode.
I have configured UCM 6.1 for a Device Pool with this SRST and configured the DP in a phone. After resetting all, the SRST does not appears in the list of CMs in the phone. Should it?
Also, the phone does not register with SRST when I stop Call Manager service at UCM. Any help?
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
user-locale ES
ip source-address 10.10.10.10 port 2000
max-ephones 20
max-dn 20
system message primary PRUEBAS
time-format 24
date-format dd-mm-yy
aramos17428 Thu, 08/13/2009 - 22:31
Can you please post the whole config?
make sure you have
ccm-manager fall-back mgcp
application
global
service alternate Default
Looking at your whole config will be better.
Armando
mcecilia Thu, 08/13/2009 - 23:25
I tested that commands and did not worked. This is the config:
Current configuration : 2872 bytes
! Last configuration change at 08:50:11 CEST Fri Aug 14 2009
version 12.4
hostname cumg02
boot-start-marker
boot system flash c2801-ipvoice-mz.124-24.T.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone cest 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
clock calendar-valid
network-clock-participate wic 1
ip source-route
ip cef
no ip domain lookup
ip domain name test.com
no ipv6 cef
ntp update-calendar
ntp server 128.90.80.1
isdn switch-type primary-qsig
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice-card 0
dsp services dspfarm
application
global
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
interface FastEthernet0/0
ip address 10.10.10.10 255.255.255.224
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:15
description QSIG a Nortel Labo
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface ATM0/3/0
no ip address
shutdown
no atm ilmi-keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip http server
disable-eadi
control-plane
voice-port 0/1/0:15
cptone ES
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.20.10
ccm-manager config
mgcp
mgcp call-agent 10.10.20.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
user-locale ES
max-ephones 20
max-dn 20
time-format 24
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
scheduler allocate 20000 1000
end
mcecilia Thu, 08/13/2009 - 23:26
May be the problem is not on the SRST. Perhaps, the phone does not try to find the SRTS. What do you think?
iptuser55 Fri, 08/14/2009 - 03:52
  • Silver, 250 points or more
A side issue, you need to add MAX-DN XXXX DUAL-LINE if you use Full-Consult as the phone need two lines to do this otherwise it will drop back to a blind transfer.
Is the Router on the same CUCM as the phones as you need both the phone and Router not register to CUCM for SRST to kick in
