Error logs on 1760 router
Aug 13th, 2009
Hi All,
I am getting the below error logs in my one of my router 1760, i found in some blogs that if no cable connected in WIC then the router is reporting the following fault on the console line and it happens every 1 minute like the device is being polled but doesn't respond.
But here cables were connected into Serial and Ethernet interfaces, still i am getting the below errors.
Is anybody experinced with this problem, can someone help me please.
Aug 14 05:30:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:31:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:32:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:33:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:34:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:35:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:36:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:37:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:38:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:39:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
Aug 14 05:40:04: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
#x
Interface IP-Address OK? Method Status Prot ocol
FastEthernet0/0 10.xx.xx.xx YES NVRAM up up
Serial0/0 unassigned YES NVRAM up up
Serial0/0.22 172.20.x.xxx YES NVRAM up up
Ethernet1/0 10.xx.xxx.x YES NVRAM up down
Loopback0 172.20.xxx.xxx YES NVRAM up up
#sh ver
IOS (tm) C1700 Software (C1700-IPBASE-M), Version 12.3(6b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 20-May-04 00:20 by dchih
Image text-base: 0x80008120, data-base: 0x80C73B38
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
CE-NUK-RG uptime is 38 weeks, 6 days, 5 hours, 36 minutes
System restarted at 00:33:21 UTC Sat Nov 15 2008
System image file is "flash:c1700-ipbase-mz.123-6b.bin"
cisco 1760 (MPC860P) processor (revision 0x500) with 55597K/9939K bytes of memory.
Processor board ID FOC08202N33 (114859209), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Naidu.
cameron.moody Thu, 08/13/2009 - 22:32
By the look of your "sh ip int bri" it is for the Eth1/0 interface not your serial.
What's plugged into the other end of that link? Have you checked it is the correct encapsulation? eg if it is a trunk, are both sides configured to be a trunk (and also both isl or dot1q)?
If it is going to a switch have you checked port security? (it may have autorecover set for 1 min which is why it keeps flapping).....
Could also be a break in the cable which causes it to be unidirectional and UDLD may be brinking it down?
ABRAHAM ATENYA Thu, 02/26/2015 - 12:48
You may also check duplex settings of the Ethernet interface.
At times changing the duplex mode from half-duplex to full duplex solves the problem.
Lucien Avramov Thu, 08/13/2009 - 22:35
  • Red, 2250 points or more
%PQUICC_ETHER-1-LOSTCARR : Unit [dec], lost carrier. Transceiver problem?
Explanation The Ethernet 10BASE-T cable is unplugged.
Recommended Action Reconnect the 10BASE-T Ethernet cable
You can see in your show ip int br that e1/0 is up/down, that is the issue.
