phone line/numbers list
Aug 13th, 2009
Hi experts,
I've been given a task to audit all our telephone numbers/lines that we are called on. We have a VG248.
Is there a way that I can see which line/number is being used by my VG248's port? ie. port 1 is 1234567, etc.
Any help here.
Thnx
Dennis Mink Fri, 08/14/2009 - 04:55
did you check your Call Manager yet an check which extensions are used on the 248 in question? each FXS port should be a device in CUCM, including an extension on that device
rob.huffman Fri, 08/14/2009 - 04:57
Hi Robert,
If you Console or Telnet into the VG248 go to;
Main Menu> Display> Port Status
You will see the DN associated with each port :)
Hope this helps!
Rob
