Problem with routing at old 2600
Aug 13th, 2009
Hi ppl,
I have nooby problem with my old 2600 router.
I have network as shown at attached picture - My PC (with IP 192.168.0.2/24 and Def GW 192.169.0.1), Cisco 2600 with 2 Ethernet ports (in - E0/1 with IP 192.168.0.1, out - E0/0 with IP 10.244.16.198) and Internet Gateway Server (with in IP 10.244.16.1/24 and out IP 80.xxx.yyy.zzz).
Cisco configuration is:
___START___
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
enable secret 5 XXXXXXXXXXXXXXX
ip subnet-zero
interface Ethernet0/0
ip address 10.244.16.198 255.255.255.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 192.168.0.1 255.255.255.0
half-duplex
interface Serial0/1
no ip address
shutdown
ip default-gateway 10.244.16.198
ip classless
ip route 0.0.0.0 0.0.0.0 10.244.16.1 permanent
no ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password XXXXXXXXXXX
login
no scheduler allocate
end
___END___
So, from My PC I can ping 192.168.0.1 and 10.244.16.198, but nothing else (even 10.244.16.1). From router I can ping everithyng (even this forum :) ).
Could you please take a look and tell me where is an error?
Thanks in advance!
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 08/13/2009 - 23:33
George
You need to NAT your internal 192.168.0.x addresses because they are not routable on the Internet so you won't get any response.
Add this to your config -
int e0/1
ip nat inside
int e0/0
ip nat outside
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
ip nat inside source list 101 interface e0/0 overload
Jon
gshengel Thu, 08/13/2009 - 23:47
I is mirracle! Just copy-paste - and everything started working!
THANKS!!!
