RME "Device Name"
Answered Question
Aug 13th, 2009
Apologies if this is a stupid question but where do RME Reports get the "Device Name" from? I'm asking because on a few reports I've tried to run, Inventory or Software Versions, I sometimes see either the IP address or the device name. I've even had double entries, one with the IP and one with the name.
Am I missing something obvious?
LMS 3.1 on Windows.
Correct Answer by Joe Clarke about 7 years 8 months ago
Device name comes from DCR display name. If you see duplicates, then both entries may be in DCR. However, it would be helpful to see a screenshot to make sure something else isn't going on.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 08/14/2009 - 00:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Richardsma Fri, 08/14/2009 - 02:00
Cheers Joe, I should've checked DCR, you're absolutely right.
