vlan gateway
mpak12345
I have one l3 switch. I want to create multiple Vlans on it but at the same time the Gateways for those vlans are different.
This is what is my current config :
ip default-gateway 192.168.0.1
vlan 3
ip address 192.168.0.2 255.255.255.0
untagged 1-24
exit
Now i want to create a new Vlans vlan100 and vlan200 whose default gateway is 192.168.100.1 and 192.168.200.1 resp.
Can anybody help?
How can i assign different gateways for two different Vlans? can we assign different gateway to different vlan?
pls suggest
vaib7av.shirkul
First create vlan 100 and 200 then follow the steps....
SW#config t
SW(config)#int vlan 100
SW(config-if)#ip add 192.168.100.1 255.255.255.0
SW(config-if)#exit
SW(config)#int vlan 200
SW(config-if)#ip add 192.168.200.1 255.255.255.0
add the interface in desired VLANs.
SW(config)#interface range fa0/1 - 10
SW(config-if)#switchport access vlan 100
SW(config)#interface range fa0/11 - 20
SW(config-if)#switchport access vlan 200
interface fa0/1 - 10 users use 192.168.100.1 as a default gateway
and int fa0/11 - 20 users use 192.168.200.1 as a DG.
Hope ur problem sort out !!!
In a little more details:
The ip default-gateway is the default gateway for the switch, if it is a L2 switch or a L3 switch in L2 mode (i.e. "no ip routing" has been configured).
The default gateway for the end users will be the IP address defined on in your case VLAN 3 for the first network and VLAN 100 and 200 for the other two, as shown in the reply.
