How to enable or disable rel1xx support on CVP 4.1
Aug 14th, 2009
Dear all,
In the gateway or call manager I can enable or disable the rel1xx.
I try to find this setting on config web page of CVP call server, but there are no parameters for this setting. I see a file on CVP/conf folder (sip); are there any way I can change this file to enable/disable the rel1xx.
Thanh
david.macias Fri, 08/14/2009 - 01:57
  • Blue, 1500 points or more
I don't see this being a setting in CVP at all, it's more of an IOS configuration only.
david
