Attack Relevancy Rating
k.dmowski
What is the internal value of the Attack Relevancy Rating for the system with relevance=not-relevant. I do not see any difference for the system with relevance=unknown. In the attachment you will find the example of an attack? It is OK or not?
Looking forward ho hearing from you
mkodali
value for ARR is adjusted as below :
- Unknown relevance : no change
- Relevant : +10
- Not-Relevant : -10 for promiscuous mode and no change for inline mode.
From the above adjustments sensor is behaving as it is supposed to be in your case. Since the risk ratings are same for system with not-relevant and unknown OS, looks like your sensor is in inline mode.
Thank you very much for your information
Best regards
Kazimierz
