PIX LAN FAILOVER
Aug 14th, 2009
Hi All,
I wanted just to check the impact of running 2 PIX 535 as Active/Standby with different Image 7.2.2 and 8.0.2
I am getting only this warning:
Any feedback is appreciated.
Jean
************WARNING****WARNING****WARNING********************************
Mate version 8.0(2) is not identical with ours 7.2(2)
Richard Burts Fri, 08/14/2009 - 03:41
Jean
It is my understanding that to run failover both PIX must be running the same version of code. I am not sure whether this is really a "warning" or whether it is really an "error". I suggest that you get both PIX on the same version of code before you run failover.
Rick
somsh Tue, 08/18/2009 - 07:02
Both Devices should be in same version.
Otherwise it will not sync.
