Tracking a static route via line-protocol
Aug 14th, 2009
When my physical link to the next hop (gateway) is up and operational, my 0/0 route is injected into my routing table - just what I need.
When the physical link to the next hop is down and not operational, I would still like to have the 0/0 route in the routing table to ensure down stream routers send unknown destination traffic this router.
I am currently using the track command but tracking does not wanna follow my direction.
Perhaps some other method would work better and/or simpler.
ANY thoughts?
THANKS again!!!!!!!
Frank
This is my config:
interface f3/1
description Network Gateway
ip add 1.1.1.0 255.255.255.254
track 1 interface f3/1 line-protocol
track 2 list boolean and
object 1 not
router eigrp 90
redistribute static - I should have a filter here, but currently don't - don't tell anyone.
net . . .
no auto-summary
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 2
Show commands when the physical link is disconnected:
R1# sh ip ro track
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 2 state is [Up]
R1# sh track 1
track 1
line protocol is down (hw down)
876 changes
tracked by:
R1# sh track 2
track 2
list boolean and
Boolean AND is Up
875 changes
object 1 not Down
Tracked by:
STATIC_IP_ROUTINGTrack-list 0
Show commands when the physical link is connected:
R1# sh ip ro track
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 2 state is [Down]
R1# sh track 1
track 1
line protocol is up
877 changes
tracked by:
R1# sh track 2
track 2
list boolean and
Boolean AND is Down
876 changes
object 1 not Up
Tracked by:
Edison Ortiz Fri, 08/14/2009 - 06:12
If you want to draw traffic even if the interface is down, don't point to the interface but point to a null0.
You can either have the null0 as your primary static route or a floating static route, it makes no difference.
ip route 0.0.0.0 0.0.0.0 null0
HTH,
__
Edison.
fsebera Fri, 08/14/2009 - 06:55
Hey Edison,
Yea I currently have 0/0 to null0 with an additional AD of 254 to ensure this would be used LAST.
I was also hoping to be able to track the number of up/downs (didn't mention this in my initial question) but perhaps SNMP would be the way to go on that one.
Also, I think the way (at what point) the router injects routes into the routing table is after the tracking function has ended. Tracking only present the data to the routing function, tracking cannot interfere with the routing decision functions.
Thanks much!!
Frank
Edison Ortiz Fri, 08/14/2009 - 07:17
And that's not working?
A Quad 0 will still be sent via EIGRP, isn't it?
Logging is incorporated if you use 'IP SLA'
If the route is associated to a track, the route will be in the RIB only when the track is up. If the track is down, the route will be removed from the RIB.
HTH,
__
Edison.
fsebera Fri, 08/14/2009 - 09:12
Oh sorry, YES, quad 0 to null0 AD 254 is working well.
But using the tracking feature does not put the quad 0 in the routing table IF the tracked next hop is down even though it shows the correct output - see original post. My quess is ... my config is broken.
Tks
Frank
Edison Ortiz Fri, 08/14/2009 - 09:31
Now I see the logic you are trying to implement, you want the route to be installed only when the interface is down?
I believe there are some caveats and I will need to lab this one out.
It may take some time so if someone else can offer assistance, please do so.
__
Edison.
