Software-forced reload on 3825
Aug 14th, 2009
Our router reboots from time to time.
When I take a look in de crashinfo I can see that it is a software related crash. but I can't find the real cause of the problem...At first I thought that SDM was installed and caused a memory leak. But this isn't the case.
I have attached the crashinfo file..
Cisco 3825 (revision 1.2) with 489472K/34816K bytes of memory.
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
Can anyone give me a tip to the solution?
Thank You,
Best Regards,
rtjensen4 Fri, 08/14/2009 - 06:30
Hi Joris,
Your best bet would probably be to open a case with TAC so they can decode the tracebacks. If that's not an option, try to just upgrade the IOS to the lastest version available.
Leo Laohoo Fri, 08/14/2009 - 20:11
Are you sure this is the correct crashinfo file? It's dated 09 July 2009.
Can you post the latest crashinfo file?
