LAN Extender as Bdrige Mode
Aug 14th, 2009
Hello
I am having Cisco LAN Extender which is having SHDSL port , i want to configure transparent (no IP ) in between two SHDSL interface is it possible or not.
Subhasis
Giuseppe Larosa Sun, 08/16/2009 - 03:17
  • Hall of Fame,
    Founding Member
Hello Subhasis,
it should be possible.
may you specify the model and the software version of the product?
it is likely that it is already doing this.
You may need to tune configuration for connecting the two shdsl back to back (one side has to pretend to be the central office CO)
Hope to help
Giuseppe
s-adhikary Mon, 08/17/2009 - 01:15
Hello Giuseppe
I am using Cisco 878 and IOS version is 12.3(8r)YI4
Subhasis
