CiscoWorks Changing Default Line Input during Config push
Aug 14th, 2009
If no line input is specified as in this example
line con 0
line vty 0 4
password cisco
line vty 5 15
password cisco
does CiscoWorks change the default line input while pushing a configuration to "transport input none"?
sbilgi Fri, 08/21/2009 - 10:57
Config Editor allows you to edit and download configuration files to devices using a GUI instead of the command line interface (CLI). Use Config Editor to edit individual device configurations within RME and then download them back to a device.
For more details please follow up on this link:
bhusebye Fri, 08/21/2009 - 12:00
Issue is when a config is pushed over the network using Cisco Works. I was wondering if it is caused by Cisco Works itself when pushing a configuration with "transport input" not listed or specified in the config. Cisco Works or something adds the line "transport input none" thus locking out the people in the network control center. I was wondering if Cisco Works was doing this or something else.
