Displaying Radio Channel Frequency
Answered Question
Aug 14th, 2009
Hi All,
Is there anyone who can tell me if there is command that I can use within the IOS on an access point (1131) that will display what radio channel it is using?
At the moment I am having to use NetStumbler to identify what channels access points are using, it would be so much easier if there was a command along the lines of 'show interface dot11radio 0 channel'
Ryan
Correct Answer by jeromehenry_2 about 7 years 8 months ago
Yes, it's easy:
show controllers dot11Radio 0
hope it helps
jerome
Overall Rating: 5 (1 ratings)
Correct Answer
jeromehenry_2 Fri, 08/14/2009 - 07:36
  • Silver, 250 points or more
Yes, it's easy:
hope it helps
jerome
williamsryan Fri, 08/14/2009 - 07:42
Thanks, that has done the trick.
I have spent ages trying to find out what the command was. I knew there had to be one somewhere.
Thanks again.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
