CSS services integrity check
Answered Question
Aug 14th, 2009
Hi Forum,
If i need to setup the load balancer to ignore a web server and direct the users to another web server when webpage error(Error501 etc) occurs, should i be looking at HTTP keepalives to achieve this?
Or is there a better approach to this?
Kelvin
Correct Answer by Syed Iftekhar Ahmed about 7 years 8 months ago
A simple HTTP keepalive with "keepalive method head" will do.
CSS will looks for the 200 OK response from the server if it get anything other than 200 then it will mark the real server as a failed server.
Syed
Overall Rating: 3 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Fri, 08/14/2009 - 11:36
  • Blue, 1500 points or more
Syed
CSCO10154079 Sat, 08/15/2009 - 01:03
Hi Syed,
Your post gave me some direction on what to research further.Thanks for the tip.
Kelvin
