VPN connection speeds really slow?
Aug 14th, 2009
directly coming off the cable modem, i am getting download speeds close to 30MB at a remote site. Once i connect via VPN, i get download speeds just below 1MB? I get 30MB from my desktop from the HQ ASA.
What could cause the poor speeds? This can't be normal. Speed tests ran via speakeasy.net/speedtest
vmoopeung Thu, 08/20/2009 - 08:28
Use the ping command to check the network or find whether the application server is reachable from your network. It can be a problem with the maximum segment size (MSS) for transient packets that traverse a router or PIX/ASA device, specifically TCP segments with the SYN bit set.
Refer to the below URL for more info:
