Phone displays incorrect Calling number
Aug 14th, 2009
CM7, H323GW. Q931 and Voice ccapi inout debugs both show correct calling number coming from PSTN, all phones display calling number as the same internal extension. This internal extension is in a different CSS. Thoughts are welcome. thanks
Anonymous (not verified) Thu, 08/20/2009 - 08:37
There is a field in the gateway configuration where you can define the Calling Party Selection:
The following options specify which directory number is sent:
Originator--send the directory number of the calling device.
First Redirect Number--send the directory number of the redirecting device.
Last Redirect Number--send the directory number of the last device to redirect the call.
In order to select "Calling Party Selection"
Go to "Device >> Gateway"
Select the gateway that you are using
Look for Calling Party Selection
Select Originator
Click Update.
