Switchport mode commands that turn off DTP
Aug 15th, 2009
Hi there, this is a question from a book. Is the answer from the exercise below complete? In addition to the answer below, I would also include "switchport mode trunk;switchport nonegotiate". Please let me know if I am missing something and the book is right.
Question:What is the correct command to set the
DTP mode of a switch port to OFF?
Answer from the book:switchport mode access
Overall Rating: 5 (2 ratings)
Peter Paluch Sat, 08/15/2009 - 03:40
The DTP packets are not sent in these three circumstances:
1.) Either the port is a static access port configured by the command switchport mode access
2.) Or the port is a static trunk port configured with the command switchport mode trunk and at the same time, the DTP negotiation is deactivated using the command switchport nonegotiate
3.) The port is a routed port configured with the command no switchport
Best regards,
Peter
babaei.saeed Tue, 07/02/2013 - 01:17
The DTP negotiation goes off in these situations:
1-     switchport nonegotiate
2-     Switchport mode access
3-     Switchport mode dot1q-tunnel
msuthar Tue, 07/02/2013 - 08:20
Please refer the below table for better clarification:-
Configuration   Command on One Side
Short Name
Meaning
To Trunk,   Other Side Must Be
switchport   mode trunk ;
NonegotiateAlways trunks on this   end; does not send DTP messages (good when other switch is a non-Cisco   switch) On
switchport   mode access;
Access (with   nonegotiate)Never trunks; does   not send DTP messages(Never trunks)
TrunkAlways trunks on this end; sends DTP to help other side choose   to trunkOn, desirable, auto
switchport mode dynamic   desirable
DesirableSends DTP messages, and trunks if negotiation succeedsOn, desirable, auto
switchport mode dynamic auto
AutoReplies to DTP messages, and trunks if negotiation succeedsOn, desirable
AccessNever trunks; sends DTP to help other side reach same   conclusion(Never trunks)
Mukesh Suthar
Please mark this as "Answered" if it resolves your query.
