LMS Log can move location?
Lucien Avramov Sat, 08/15/2009 - 08:33
The logs folder path can not be changed however, you can enable log rotation and then move the rotated files to another disk.
Here is how, section using logrot:
Another option for you, if you are running out of space is to make a full backup of LMS, install it on another drive and restore the backup.
It all depends on what is the main reason that you want to move the logs.
Joe Clarke Sat, 08/15/2009 - 08:33
While you can certainly copy the log files anywhere you want, they cannot be relocated within the application. Instead, consider configuring logrot.pl to rotate the log files, and keep their sizes down. In LMS 3.1 and higher, logrot can be configured in the GUI under Common Services > Server > Admin > Log Rotation. On earlier versions, search the Common Services online help for "logrot".
