CME Challenge
Aug 15th, 2009
Can any one suggest how to implement the below requirement
1) Particular extensions should have option to dial 0 (zero) to call mobile and they should enter password when they dial the zero digit.
Jaime Valencia Sat, 08/15/2009 - 12:28
COR + FAC
FAC UC500
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd45262
The other usual option is as Paolo mentions "use after-hours and PIN login"
Plenty of posts on the matter, if you require more info search NetPro.
java
if this helps, please rate
