SGE2000P config save
Aug 15th, 2009
If I make a change to the config on my SGE2000P via the GUI, do I manually have to save the running config to the startup config like in Cisco land, or does it behave like a Linksys where as soon as you click "apply" the change is automatically saved and thus persistent across reboots?
chrcoope Mon, 08/17/2009 - 09:31
  • Bronze, 100 points or more
It must be saved. I have attached a doc that shows where this is done. Hope this helps.
Christopher
