FAC UC500
Aug 15th, 2009
Hi, I configure the UC500 whit the following commands to enable the Force  Authorizatin Code:
application
service clid_authen_collect
param  uid-len 3
param pin-len 3
aaa new-model
aaa authentication login  h323 local
aaa authorization exec h323 local
aaa authorization network  h323 local
username 452 password 452
username 452 autocommand exit
dial-peer cor custom
name internal
name local
name  international
name international-fac
dial-peer cor list  call-international-fac
member international-fac
dial-peer cor list  user-international-fac
member internal
member local
dial-peer voice 10 pots
tone ringback alert-no-PI
destination-pattern  9[1-9]T
direct-inward-dial
corlist incoming call-international-fac
corrlist outgoing call-international-fac
ephone-dn 20 dual-line
corlist incoming user-international-fac
dir flash:
enter_account.au
enter_pin.au
But the call is established  whitout enter the username and password. The call is established without  problem. but the prompt is not heard. What is the error o missing in the  configuration?
Source: https://www.myciscocommunity.com/docs/DOC-1400;jsessionid=E5DC5DD8503D5F829C71F08FFF02C2B8
ThomasBond_2 Sun, 08/16/2009 - 10:59
Hi Marcos,
But the application dont trigger with POTs dial peer ? I need enable FAC to international call (PSTN).
(Yo necesito habilitar FAC para las llamadas hacia la red publica PSTN, ¿Se puede activar FAC para dial-peers tipo POTS?)
Gracias
Marcos Hernandez Sun, 08/16/2009 - 14:44
  • Blue, 1500 points or more
To trigger the application, it is necessary to use a H.323 loopbacck dial peer. Your POTS will be used for routing still, but you need the VOIP peer.
El uso del dial peer voip es obligatorio. Lo necesitas para que se active el script que luego te presenta la voz prepragabada y que controla todo el tema de accounting. Esta explicado en el ejemplo que te mande.
Saludos,
Marcos
ThomasBond_2 Sun, 08/16/2009 - 15:23
Ok, de acuerdo Marcos.
Pero mi necesidad es habilitar FAC especificamente en el DP siguiente:
direct-inward-dial
En este escenario como lo hago ??
Muchas Gracias
Marcos Hernandez Sun, 08/16/2009 - 15:27
Quita el comando "service" de tu DP POTS y anade "preference 5". Luego, anade este DP:
dial-peer voice 5500 voip<br/> description International Calls<br/> service clid_authen_collect<br/> destination-pattern 9[1-9]T<br/> session target ipv4:10.1.1.1<br/> incoming called-number 9[1-9]T
dtmf-relay h245-alphanumeric<br/> codec g711ulaw<br/> no vad<br/>
e intenta la llamada internacional desde un telefono IP.
Saludos,
Marcos
ThomasBond_2 Sun, 08/16/2009 - 15:37
Entonces quedaria la siguiente configuracion:
direct-inward-dial
preference 5
codec g711ulaw
no vad
(La ip del session target deberia ser la IP del CCME?)
FAC es mucho mas simple el Call Manager Exterprise
ThomasBond_2 Wed, 08/19/2009 - 22:58
Hola Marcos,
He implemetado FAC, personalize el promt que solicita username y password, la autenticacion es correcta de la misma manera el establecimiento de la llamada. El problemas es que el prompt o la autenticacion es presentada al usuario de manera aleatoria, esto quiere decir que por ejemplo el usuario A marca a un numero X la autenticacion es satisfactorio y la llamada tambien, luego de unos instantes el mismo usuairo nuevamente llama al numero X y la autenticacion no es presentada (nose ingresa username) y la llamada es establecia sin autenticacion.
Esto es normal ?
Desde ya gracias !!
Saludos
Marcos Hernandez Thu, 08/20/2009 - 05:39
No, esto no es normal. Lo que esta pasando aqui es que el dial peer que invoca la aplicacion (VOIP) no esta siendo seleccionado el 100% del tiempo. Debes tener un problema de preferencia. Asegurate que otros dial peers con el mismo destination pattern tengan el comando "preference 5" por ejemplo, mientras que tu dial peer de la aplicacion debe tener "preference 0" (que es el default y por lo tanto invisible).
Saludos,
Marcos
The problem is that the caller is being presented with the authentication prompt only 50% of the time. This is likely due to an incorrect preference setting between dial peers with the same destination pattern. The loopback dial-peer (the one that invokes the application) should have the lowest preference (preference 0) while others should be set with a higher preference (which in reality means selection order).
ThomasBond_2 Fri, 08/21/2009 - 08:50
Ok, Gracias Marcos por tu apollo.
Mira esta es mi configuracion actual:
application
  param uid-len 4
  param pin-len 4
username 8914 password 6732
username 8914 autocommand exit
name internal
name local
name international
destination-pattern 9[2-9].....
direct-inward-dial
port 0/0/0:15
dial-peer voice 11 pots
destination-pattern 9156[1-9]T
direct-inward-dial
port 0/0/0:15
dial-peer voice 12 pots
trunkgroup Outgoing
destination-pattern 909[6-9].......
direct-inward-dial
dial-peer voice 15 pots
destination-pattern 91560T
direct-inward-dial
port 0/0/0:15
dial-peer voice 711 voip
corlist outgoing call-international-fac
session target ipv4:192.168.78.1
incoming called-number 9156[1-9]T
preference 5
codec g711ulaw
no vad
dial-peer voice 715 voip
description Llamados LDI
incoming called-number 91560T
preference 5
codec g711ulaw
no vad
dial-peer voice 712 voip
description Celular
incoming called-number 909[6-9].......
preference 5
codec g711ulaw
no vad
ephone-dn  28  dual-line
  number 6675
ephone-dn  29  dual-line
  number 6676
Si bien las preferencias correspondientes estan aplicadas, aun sigue el sintoma. Alguna Sugerencia?
Gracias !.
Marcos Hernandez Fri, 08/21/2009 - 09:00
Los tienes al reves. El dial-peer voip, tal y como te dije en mi post anterior, debe tener preferencia 0, no 5. Otra cosa, estos foros son para UC500 exclusivamente y no ISR/CME que es lo que estas usando. Para soporte tecnico del ISR/CME, puedes usar Netpro o abrir un caso con el TAC.
Un saludo,
Marcos
I have recommended the customer to contact Netpro or TAC. These forums are not for ISR/CME support.
Imthiyas Khan K I Thu, 08/26/2010 - 01:04
  • Bronze, 100 points or more
Hi Marcos,
I have a similar configuration for UC520, but call is going out without FAC
application
  param uid-len 3
  param pin-len 3
name International
name National
name National_Restricted
name Manager
dial-peer cor list International
member International
dial-peer cor list National
member National
dial-peer cor list Manager
member National
dial-peer cor list NationalRestricted
member National_Restricted
dial-peer voice 801 voip
description International Calls Authentic
preference 1
destination-pattern 900.T
session target ipv4:10.1.10.1
incoming called-number 900.T
codec g711ulaw
no vad
dial-peer voice 80 pots
corlist outgoing International
description **International**
translation-profile outgoing callingnumber
preference 2
port 0/2/0:15
forward-digits all
no sip-register
ephone-dn  14  dual-line
number 151 no-reg primary
label 151
call-forward busy 132
call-forward noan 132 timeout 20
corlist incoming Manager
jason.yipngow Thu, 08/26/2010 - 06:33
Under dial-peer voice 801
session-target ipv4 should point to 10.1.1.1 not 10.1.10.1
therefore:
config should be as follows
conf t
dial-peer voice 801
session-target ipv4:10.1.1.1
exit
You will still have a little bit of changing to do after, but that should ensure you get the FAC prompt code.
rgds.
Imthiyas Khan K I Fri, 08/27/2010 - 14:51
Thank you Jason,
It's working working now, now am able to get the prompt.
after entering the user name and password, the call is disconnecting without any message.
do i need to do anything more..
regards
Imthiyas
nils_guerrero Thu, 01/23/2014 - 09:03
Buenas tardes Marco, tengo un UC540 he intentado replicar esta config pero nunca logro que se reproduzca los audios para la autenticación y contraseña. Aquí está mi config:
application
  param max-retries 3
  param passwd-prompt flash:enter_pin.au
  param passwd 54321
  param user-prompt flash:enter_account.au
  param term-digit #
  param abort-digit *
  param uid-len 3
  param max-digits 32
  param pin-len 3
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
member internal
member local
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer voice 91 pots
trunkgroup ALL_FXO
description **CCA*Venezuela*International Calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
forward-digits all
no sip-register
dial-peer voice 2500 voip
session protocol sipv2
session target ipv4:10.2.1.1
voice-class sip outbound-proxy ipv4:10.1.10.1
codec g711ulaw
no vad
ephone  5
device-security-mode none
mac-address 04C5.A4B0.0955
ephone-template 16
username xxxxx
paging-dn 1
type 7911
button  1:289
Agradecido de antemano,
Saludos
hugosaavedra1 Wed, 02/05/2014 - 05:35
hola Marcos te comento que tengo el problema con UC-560 no puedo hacer uqe me pida el codigo en los dial peer pots queria ver si me podria hechar una mano he seguido los comentarios anteriores pero no esta funcionando
dial-peer voice 58 pots
corlist incoming call-national
corlist outgoing call-national
description **CCA*IDEAY*Llamadas a Fijos**
preference 5
destination-pattern 9.T
port 0/3/0:15
forward-digits 8
description NACIONALES
service clid_authen_collet
session target ipv4:10.2.2.1
incomming called-numbre 9.T
dtnf-relay h245-alpahnumeric
codec g711ulaw
no vad
felixguzman Tue, 11/06/2012 - 08:06
Que tal Marcos, una pregunta es posible enviar el codigo de cuenta y pin via servidor syslog ???
Veo que via Servidor Radius, si veo el codigo de cuenta y pin, pero en servidor syslog no recibo tal informacion, no veo tal campo que tenga tal informacion, esto lo requiero para cuestiones de ver el consumo de tal clave asignado.
Gracias
Saludos, FGA
