ASA or FWSM
Aug 16th, 2009
Hi everyone,
Can anybody guide me by suggesting which one could be a better choice between a ASA and FWSM in a Datacenter environment with many VLAN's and segments. I found FWSM to be very intricate. Any suggestions would be very valuable. Thanks
-- Faiz
mmacdonald70 Sun, 08/16/2009 - 04:29
I depends on your requirements. I have always preferred to use the FWSM for datacenter environments, especially if I am using a 6500 for the DC core since it is all there. You can also team to FWSM modules together to give you 10GB of thoughout.
ASA is better for environments with defined borders.
Mohammed Faiz M... Sun, 08/16/2009 - 05:59
Hi Macdonald,
Thanks for the reply. But what i have seen in technical documents and sample configs the FWSM has some limitations regarding certain things as compared to an appliance itself. I have to make myself fully satisfied before ordering the FWSM's to replace the PIX which are doing the job currently. The non-exsistence of physical interfaces on FWSM, i feel is making the configurations a little bit difficult i guess and i also feel the placement of VLAN's will be critical while designing / configuring security contexts, that too with just the default 2 contexts. Any more inputs on this will be highly useful for me. Thanks.
-- Faiz
