linksys router most probably dropping skinny trafic over internet
Aug 16th, 2009
I have a scenario where I want users having softphones and nokia cells register through sccp to a published public call manager on the internet. The setup is working fine when users are assigned directly a public ip but whenever they have private ip behind linksys routers, the setup isn't working.
Any hints? I tried btw to remove all DoS checks on the linkys router without any results
Paolo Bevilacqua Sun, 08/16/2009 - 14:05
For sure the linksys don't support SCCP.
Use VPN on laptopt and cellphones, there's no way around it, or you will be driven crazy in very short time.
k.abillama Sun, 08/16/2009 - 21:48
Hi, I already tested Site to Site VPN with the linkys I have and it worked fine.
I'm eager to know if you're sure there is no workaround; I have the linksys WRV200.
Paolo Bevilacqua Mon, 08/17/2009 - 04:36
As mentioned above, there is no workaround. Linksys does not support SCCP.
If you want a cisco telephony solution to work as supposed, must use cisco products end-to-end. There is no way around that.
