FWSM intervlan communication failing.
Aug 16th, 2009
Hi ,
I have setup FWSM in my lab , and configured a security context named it "test" and configured 3 vlan interfaces on it. I have disabled the NAT between these interface traffic. below is the setup.
inside - 10.1.3.1 / 255.255.255.0
inside-2 - 10.1.4.1 /255.255.255.0
outside - 8.19.65.1/255.255.255.252
From inside interface i am unable to ping inside-2 interface IP and viceversa, can somebody please adavice.
both are directly connected interface.
vikram_anumukonda Sun, 08/16/2009 - 18:20
by default a FWSM does not allow traffic between interfaces without an access-list applied unlike and ASA/PIX.
Kevin Redmon Sun, 08/16/2009 - 18:29
Arjun,
Can you please provide the output of 'show nameif' and 'show ip addr'? If you are referring to pinging the actual IP address of the "far-side" interface, this is NOT supported on any Cisco Firewall, unlike Cisco routers.
If you are pinging hosts off of the interface (not the interface itself), the output of 'show nameif' as above will provide insight. If the two interfaces are at the same security level, it may also be 'same-security-traffic permit inter-interface'.
Hope this helps. If you still need assistance, please provide the output requested above.
arjun_ankathil Sun, 08/16/2009 - 20:38
Please find the outputs below. permit inter-interface was already added.
FWSM/test# sh nameif
Interface Name Security
Vlan100 outside 0
Vlan101 inside 100
Vlan112 inside-2 100
FWSM/test# sh run | in permit inter
FWSM/test# sh int ip br
Vlan100 8.19.65.1 YES CONFIG up up
Vlan101 10.1.3.1 YES CONFIG up up
Vlan112 10.1.4.1 YES CONFIG up up
10.1.4.2 is another switch connected the FWSM. on vlan 112, below is the ping response.
FWSM/test# ping 10.1.4.2
Sending 5, 100-byte ICMP Echos to 10.1.4.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
FWSM/test# ping inside 10.1.4.2
Success rate is 0 percent (0/5)
Below is the log i get when I ping 10.1.4.2 using inside interface. says no route, however these are directly connected routers.
Aug 17 2009 04:30:30: %FWSM-5-111008: User 'enable_15' executed the 'ping 10.1.4.2' command.
Aug 17 2009 04:30:41: %FWSM-6-110001: No route to 10.1.4.2 from 10.1.3.1
Aug 17 2009 04:30:51: %FWSM-5-111008: User 'enable_15' executed the 'ping inside 10.1.4.2' command.
Kevin Redmon Thu, 08/20/2009 - 13:15
As Vikram stated, the 'ping inside' command implies to send the ping out the inside interface. The FWSM maintains a route table on a per-interface basis. As a ping 'inside' command, we'll reference the route table for the 'inside' interface.
These route tables also come into play when a bad translation is formed through the FWSM. The route table for the egress interface will be referenced when processing the packet.
arjun_ankathil Thu, 08/20/2009 - 20:04
Thanks Guys for the clarity on the command, i mistook this command for the cisco source interface option.
However I have been facing problems in ping between the servers connected to inside and inside-2 interfaces as mentioned in the 1st post of this netflow discussion.
