6509E Switch support MPLS VPN
Aug 16th, 2009
Hi Friends,
I have a 6509 Swich with FWSM, 6724SFP, and 6748 Modules on it. As of now it is acting as the core swith of my network. I have a router at the perimeter connecting to the WAN. I have a new MPLS VPN link from the Telco now, since there is no free port on the router, can i connect this link to the Core Switch on any of the Line cards(6748 or 6724 module)
appreciate your valuable input
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Sun, 08/16/2009 - 10:29
Hello Jacob,
yes you can because from your point of view it is a normal link the MPLS VPN is defined on the provider side.
to use a port as a routed port
int gix/y
no switchport
ip address x.y.z.k 255.255.l.n
(actually no switchport is the default on a C6500)
You may need to redistribute routes learned on the new link in a dynamic routing protocol
Hope to help
Jacob Samuel Sun, 08/16/2009 - 11:13
Hi guisee,
Thanks for the reply. In that case what is the VPN module on the 6509 switch?
thanks and regards
Giuseppe Larosa Sun, 08/16/2009 - 11:21
Hello Jacob,
a vpn module is used for IPSec based VPNs to perform encryption / decryption in hardware but it is a different type of VPN.
Hope to help
