ISDN Config
Aug 16th, 2009
can anybody provide me ISDN Config for backup serial interface.(complete config)
Mumbai(PRI)--------Branch(BRI)
This is basic question but help is apreciable....
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Sun, 08/16/2009 - 10:47
Hello Ariujn,
you can use the file in attachment that shows the usage of dialer pools and dialer interfaces.
notes:
you need to verify the ISDN switch type on each side with the provider.
it is very important to define what is the interesting traffic that can trigger a call and can keep the link up.
Failing to do this leads to high bills to be payed
BRI requires a slightly different configuration but it can use the dialer profiles.
Hope to help
Giuseppe
arjunsawant Tue, 08/18/2009 - 02:40
Hi Giuseppe...
Thanx for reply.
Pls find the attachment and help me to figure out this config.I want to configure autobackup, when my Rel link goes down my isdn will fire automatically.
Which steps require for avoiding unnecessary auto isdn Firing.
Thanx in advance....
Giuseppe Larosa Tue, 08/18/2009 - 08:05
Hello Arjun,
the key point is this:
dialer-list 1 protocol ip permit
you should use an extended ACL
dialer-list 1 protocol ip list 111
to define exactly what traffic is considered interesting
Hope to help
Giuseppe
arjunsawant Tue, 08/18/2009 - 23:10
Hi..
Thanx once again..
Is config correct?
ip access-list extended 111
permit ip 10.57.4.0 0.0.0.255 200.1.9.0 0.0.0.255
deny udp any any eq ntp
Also on serial interface:
backup interface bri 0
Thanx......
