Incoming SIP Calls to CUBE not working correctly
Answered Question
Aug 16th, 2009
Dear All,
Is there a way to change the INVITE port to non 5060 ?
My provider is saying that my CUBE is dropping calls because its not accepting INVITE from non 5060 ports.
The port for the INVITE and contact header do not match and their ACK for The 200 OK go to port 5060 and my CUBE is not getting the ACK they send.
I should change the INVITE port from a non 5060 so it matches what the CUBE sends in the contact header.
Any input of comment on this will be greatly appreciated.
Correct Answer by gogasca about 7 years 2 months ago
for outgoing calls invite can be change using session target ipv4:
for incoming:
Overall Rating: 5 (1 ratings)
