FXO - H.323-CUCM6 - PLAR - IP Phone- Caller-ID not working
Aug 16th, 2009
Hi there,
This is happening across 5 remote sites which just got cutover from basic Key systems to IPTel.
PSTN into FXO, PLAR to IP Phone and no Caller ID, just comes up with unknown number. Caller ID working on outgoing calls but thats the carrier setting that.
Router types are various;
1861 - VIC2-4FXO - 124-11.XW6.bin
2801 - VIC2-4FXO - 124-22.T.bin
Config.
voice-port 0/2/0
cptone AU
connection plar opx 708
impedance complex1
caller-id enable
debug says
.Aug 16 23:36:17.996: [0/2/0] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
So I'm not seeing Caller-ID but it was working before and a cheap $5 phone connected shows Caller-ID.
Reading other problems people say its still a carrier problem but what kind of problem or is it something on my end I can try. I've tried lots of thing with commands but no luck.
paolo bevilacqua Mon, 08/17/2009 - 04:33
  • Hall of Fame,
    Founding Member
Can you try CPtone US ?
And different options under caller-id enable.
If nothing works, you have to prove your case to cisco.
This is the reason BRI is always recommendable, no issues like always happens with FXO.
