Clear ip opf process command
Answered Question
Aug 16th, 2009
  • Bronze, 100 points or more
Hi every body.
My book says " ospf can be restarted with the clear ip ospf process command,but depending upon on circumstances,ios still may not change its ospf-RID until the next ios reload.
My question what could prevent router from changing its ospf router id even upon issuing clear ip ospf process ?
Thanks a lot
Correct Answer by Lucien Avramov about 7 years 8 months ago
i would only see a bug or a crash. In all my years of experience, I was always able to change the RID with a clear ospf process.
Really not sure why your book is mentioning this, perhaps they had in mind specific bug on certain code of IOS.
Overall Rating: 5 (1 ratings)
Correct Answer
Lucien Avramov Sun, 08/16/2009 - 17:58
  • Red, 2250 points or more
fjcardenas-1 Mon, 08/17/2009 - 04:55
In may home lab i changed the RID but "clear ip ospf" didn't work.... I had to reload the router. I don't know the reason of this but it worked only after the reload.
