Warning message
800 Series - Site to site VPN
Aug 16th, 2009
I am designing a solution for a customer that needs to connect two small office locations.
Ideally, I would suggest they purchased a Frame Relay connection between each office, but their monthly budget may not allow this.
So, I am going to propose a site to site VPN solution. Both locations have 6Mbps DSL down and about 512Kbps up. The site to site connection would be up at all times.
The type of traffic that would go across the pipe is transactional information. Nothing too bandwidth intensive.
I plan on utilizing two 800 series routers behind an existing DSL modem that will set up as a pass through so that the public IP information will be assigned to the router.
What are some issues to be aware of with this setup. Can routing protocols (OSPF or EIGRP) be run across the IPsec VPN tunnel? Is the configuration straitforward?
Thank you in advance for any advice.
Leo Laohoo Sun, 08/16/2009 - 18:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Depending on how many VPNs you want to support, the newer 880 and 890 will support OSPF and EIGRP (IP and IP Services).
The older 870 also BGP, OSPF and EIGRP.
Comparison Chart and Data Sheets for the 870, 880 & 890 below:
800 Series Models Comparison Chart
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
Cisco 870 Series Integrated Services Routers for Small Offices
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
Cisco 880 Series Integrated Services Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.html
Cisco 890 Series Integrated Services Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-519930.html
Hope this helps.
bflseanny Mon, 08/17/2009 - 08:29
Would I have to do GRE tunnelling to use routing protocols over the IPsec VPN?
